tahstylo :
jimmysmitty :
If this is the HDD you are loaded to then you cannot change it. The only way to change it would be to install Windows on the SSD then plug the HDD in and change it when it is not loaded.
Okay so for starters i've realised I've done some stupid things, that lead up to this point but basically I cloned my HDD onto the SSD today and so windows should be on it right?
Here, and in your other thread...
You need to start over.
Your SSD should NOT end up as the B drive. At all. Ever.
So....Assuming you have not wiped out your old HDD
Redo the clone thing.
When it is done, power off
Disconnect the old HDD
Power on, and check the boot order in the BIOS. SSD first.
Continue the boot, and see if it starts up properly.
