Its my first build im a bit nervous about everything not working :)
MyminiCookie
4
Intel Core i5-7600K 3.8GHz Quad-Core Processor
NZXT Kraken X52 Liquid CPU Cooler
Asus STRIX Z270-E GAMING ATX LGA1151 Motherboard
Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory
Sandisk SSD PLUS 120GB 2.5" Solid State Drive
Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive
Asus GeForce GTX 1060 6GB 6GB Strix Video Card
NZXT S340 Elite (Black) ATX Mid Tower Case
EVGA 500W 80+ Bronze Certified ATX Power Supply
is this build good for heavy gaming and overall browsing,youtube but mostly AAA games
What you have will work.
But... I have some thoughts:
1. Liquid cooling is no more effective in a good case like yours than air cooling.
I suggest a scythe kotetsu for $35.
Here is a review:
http://www.silentpcreview.com/Scythe_Kotetsu
See my liquid cooling rant at the end.
2. Ram is fine, I like lpx. If 2400 speed is cheaper, buy it.
There is little benefit from 3000 speed overclocked ram.
http://www.silentpcreview.com/article1478-page1.html
3. 120gb is too small for a ssd these days. 240gb at least.
If you can buy 500gb, defer on the hard drive until you actually need the space.
Today, I would only buy Samsung evo for performance and reliability.
Also, WD is better for hard drive reliability.
4. 450w is fine for...
CPU: Intel Core i5-7600K 3.8GHz Quad-Core Processor ($238.75 @ OutletPC)
CPU Cooler: CRYORIG H5 Ultimate 76.0 CFM CPU Cooler ($56.49 @ OutletPC)
Motherboard: MSI Z270 PC MATE ATX LGA1151 Motherboard ($124.99 @ B&H)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory ($104.99 @ Newegg)
Storage: PNY CS1311 240GB 2.5" Solid State Drive ($79.99 @ Best Buy)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($69.89 @ OutletPC)
Video Card: MSI GeForce GTX 1060 6GB 6GB 6GT OC Video Card ($249.89 @ B&H)
Case: NZXT S340 Elite (Black) ATX Mid Tower Case ($89.99 @ SuperBiiz)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply ($49.99 @ B&H)
Total: $1064.97
Generated by PCPartPicker 2017-02-15 20:34 EST-0500
Personally I'd prefer this. No reason on earth to drop a $150 cooler on a 7600k. I bet this is still cheaper than your setup even with the SSD. Might could Upgrade to a 1070 and still be under?
i have a budget for under 1800$ put yeah i know put i just love how the nzxt x52 looks
Here is a review:
4. 450w is fine for GTX1060.
I have no problem overprovisioning a PSU a bit. Say 20%.
It will run cooler, quieter, and more efficiently in the middle third of it's range.
A PSU will only use the wattage demanded of it, regardless of it's max capability.
That evga psu is not one of their best.
I would look for a Seasonic S12II 520/620w unit which is a tier 2 unit on this list:
http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html
5. Love the i5-7600K for gaming.
As of 1/13/17
What percent of samples can get an overclock
at a vcore around 1.4v.
I5-7600K
5.1 28%
5.0 52%
4.9 72%
My canned rant on liquid cooling:
------------------------start of rant-------------------
You buy a liquid cooler to be able to extract an extra multiplier or two out of your OC.
How much do you really need?
I do not much like all in one liquid coolers when a good air cooler like a Noctua or phanteks can do the job just as well.
A liquid cooler will be expensive, noisy, less reliable, and will not cool any better
in a well ventilated case.
Liquid cooling is really air cooling, it just puts the heat exchange in a different place.
The orientation of the radiator will cause a problem.
If you orient it to take in cool air from the outside, you will cool the cpu better, but the hot air then circulates inside the case heating up the graphics card and motherboard.
If you orient it to exhaust(which I think is better) , then your cpu cooling will be less effective because it uses pre heated case air.
And... I have read too many tales of woe when a liquid cooler leaks.
google "H100 leak"
I would support an AIO cooler only in a space restricted case.
-----------------------end of rant--------------------------
Your pc will be quieter, more reliable, and will be cooled equally well with a decent air cooler.
This is more than enough.
CPU: Intel Core i7-7700K 4.2GHz Quad-Core Processor ($343.33 @ OutletPC)
CPU Cooler: CRYORIG H5 Universal 65.0 CFM CPU Cooler ($46.88 @ OutletPC)
Motherboard: Asus STRIX Z270H ATX LGA1151 Motherboard ($163.99 @ SuperBiiz)
Storage: Samsung 850 EVO 250GB M.2-2280 Solid State Drive ($96.93 @ Jet)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($69.80 @ OutletPC)
Video Card: EVGA GeForce GTX 1080 8GB Superclocked Gaming ACX 3.0 Video Card ($559.99 @ Newegg)
Case: NZXT S340 Elite (Black/Red) ATX Mid Tower Case ($84.99 @ Amazon)
Power Supply: FSP Group Hydro G 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($84.99 @ Newegg Marketplace)
Total: $1555.89
Generated by PCPartPicker 2017-02-15 20:58 EST-0500
