Hello master..
I just find out and explain me a lot for all these years that i was wondering why my intel hd graphic control panel (motherboard intel hd chipset tru vga port) setting suddently missing from taskbar also having problems as not startup/running at window boot even it was succesfully install and re-install so many times but still wont launch from exe it self so which in result none options is enable/available for me change the display setting for my intel hd chipset graphic. (Then noob was born at firstplace that probaly caused is to excited had gtx 9** series on 5 years back from now lol) Since that i disable intel hd graphic in bios put gtx as primary graphic for all task gaming etc and leave them like that as just only use one display port rather than use both because im not sure which is the correct one? For me no much difference base on performance but less on configure options and setting.
Fyi:
im using nvidia gtx950 graphic card with connection type is tru hdmi port to monitor hdmi port cabel on same monitor at the time and
Gigabyte H81m gaming 3 motherboard as my Intel hd graphic i mentioned about
with connection is tru vga port to monitor vga port cabel. On same monitor at the time
Btw i have not actually monitor build for pc i dont know what they call for me its just LCD TV that have vga and hdmi port came from difference souces example HDMI 1 for displaying connected port 1 and HDMI 2 for displaying connected on port 2 and 3 so be it
Result:
Third party software for both card nvidia control panel and internal hd graphic soft will run without problem as long as the both vga cabel and hdmi cable devices is connected to my monitor.
The good and weird thing im not sure if this is normal or not but these both port that connect to pc and to my tv monitor vga and hdmi as known came from differance adapter board card and pci card and also sent the signal to difference of my tv port souces as well. In logic thinking that should only be able to swithed 1 souces at the time right? Example is about watching dvd and waching TV on same display but how can we watch both of them at same time in fact the true is we have to switch the
input chanell according his souces port that was connected and recieved the singnal. That was very cool when both port are connected i can see my intel hd display controller appeard on taskbar also with nvida controller which mean they both adapter was config into one display very well or it might having hidden defect that can lead to low performance and stability or crashed caused by fps drop without reasonable interfere on certain task or programs.
Question:
1. Is there any sort of programs is required both graphic adapter run together at same time at same on one monitor to optimize performance and stability purposed?
Any answer, suggestion, correction is highly appreciated and most welcome thanks
Fyi:
Result:
Question:
