Hello,
I was wondering if there were any mini-ITX cases that supported vertical gpu mounts? I was planning on building a full custom loop in an NZXT H200, by thought the vertical GPU would add to the general esthetic. I know Phanteks' Evolv Shift technically would fit my description, but I have a 240mm rad to put in there, and there's no place for such in that case. The case doesn't also have to specifically be an ITX enclosure, but due to dimension constraints it has to be under 40cm tall, preferrably even 36cm (hence the choice of the H200).
