Question ITX conversion
May 14, 2021
6
Hi everyone I have a microatx pc and now i want to change it with an itx project.
My current configuration is:
View: https://imgur.com/aScFFhI
I recently won an auction for a Silverstone Sst-RVZ02 and would like to purchase a suitable motherboard.
Gigabyte B450I Aorus could support a ryzen 3600? And 3700x?
I use the Adobe suite to edit FullHD videos, Is the ryzen 5 3600 equally good for video editing / gaming?
Thank you!
I suggest you look at some reviews of builds using that exact case.
ITX builds are challenging.
One issue is likely the need for a sfx power supply.
Another is what to do with a 3.5" HDD.
You may not be able to fit one.
A cooler less than 58mm will be required.
Any of the R5 processors with 12 threads are going to perform about the same.
Probably not worth changing.
May 14, 2021
6
Ok perfect.
But my old Toshiba p300 2TB 3.5 "HDD doesn't fit in the case.
Using an external SATA converter cable is not detected ... does it need to be powered?
Do I need to buy a powered external box?
Ok perfect.
A 3.5" HDD needs more power than a single usb port can deliver.
You will need a powered adapter or possibly an adapter with two usb connections.
If you will use this hdd on a regular basis, buy a powered usb enclosure. They are not expensive.
If the hdd is to be used as a backup device(a good thing) look for an enclosure with an on/off switch to isolate the device after backing things up.
As to coolers, noctua nh-l9I is one of the best.
Scythe big shuriken 2 would also work.
Reactions: Bebop'n'Rocksteady
