[SOLVED] ITX Cooler, between Cryorig C7/Silverstone AR06/Noctua L9/Scythe BS Rev2
Feb 17, 2019
i wanna know what of these are the best cooler (and with a nicely priced) for a custom ITX build, all fit, i only wanna a nice cooler, i liked the C7, my problem with him is this coler had no screw holes for another fan so this is bad since i wanna replace the stock cooler for a noctua or something, i will use Gelid GC Extreme as cooling paste, a recomendation?
Reeven Brontes or beQuiet Shadow Rock LP.
Not a fan of the Reeven color scheme, so for me the Shadow Rock LP is the clear winner, but with no height limit, the beQuiet Dark Rock TF would also be a good choice at 131mm. Sports dual fans.
