Hello.
Well basically the problem is is windows is not installing anything. I had a drive crash the other day and when trying to boot it back up got stuck in windows boot manager. I couldn't find out the solution or a fix so I tried some things through the bios and booted it up on to at the previous time was my E:/drive which is now my C:/drive.
Anyways I had windows 7 OEM home edition and anyways I can't seem to install vc_redist.exe at all I keep getting stuck on the MSU part and my mate told me to upgrade to windows 7 professional and gave me the files to do that. So I did that hoping that it would fix things and it hasn't changed anything.
The problems are is that I cannot fully install Visual C++ Redistributable for Visual Studio 2015 because I get an error that pops up or it just hangs.
The hanging issue happens for everything. Windows standalone installer, Windows updates, The MSU error downloading the redistributable. I don't know a work around and would appreciate a response from anyone who has had a similar issue and has a workaround.
If anything else is required to assist you please don't hesitate to ask. I do need those files to work somehow
