Hey guys!
So I've noticed that I've developed a heat issue. I currently am running a Intel Core 2 Duo e6300 at sock speeds. When playing a few hours of WoW I noticed that I see a lot of random lines shotting across my screen. It seems like a lot of angles are being insanely stretched across my screen. I naturally thought that this was a video card issue so I updated my ATI driver (X1900XTX).
This didn't solve the problem. I just ignored the issue. Then I noticed that after continued playing my system would hang then shut down. I checked the BIOS and noticed my Core 2 Duo is running at 59-62 degrees C. This isn't good at all! I'm using the stock cooler. So I'm thinking about upgrading the heatsink and fan and I noticed this:
http://www.frozencpu.com/products/5694/cpu-cma-13/Cooler_Master_GeminII_Dual_120mm_Universal_CPU_Cooler_-_Socket_754_775_939_940_AM2_-_RR-CCH-ANU2-GP.html#blank
Do you think that the above cooler would fit on a http://www.newegg.com/Product/Product.aspx?Item=N82E16813128017
Inside a
http://www.frozencpu.com/products/image/1681/cst-388.jpg/cst-388/Thermaltake_Matrix_VX_Mid_Tower_Case_Side_Panel_Window_Black_VD3000BWA.html?tl=g1c7s28
Inside a
