S seedzzz Commendable Jan 14, 2017 2 0 1,510 Jan 14, 2017 #1 got Radeon rx460 graphics card and i dont know what i need to make them work.
Solution Z Z ZapBoy Feb 4, 2017 seedzzz : I've got that DVI-D to VGA adapter but won't work 🙁 The DVI-D won't work, get a DVI-I instead, they're not the same! Hope this helps
The Paladin Titan Ambassador Oct 5, 2016 9,659 63 75,340 Jan 14, 2017 #2 your Radeon actually has DisplayPort 1.3 out, one HDMI 2.0 out, and a DVI out. Display port to VGA: https://www.amazon.com/gp/product/B007N6MTNA?gclid=CjwKEAiAtefDBRDTnbDnvM735xISJABlvGOv3XZKVjh90WWyDQf0C5Jr01-JnZgou-8MNBQ3LOvemxoC6Urw_wcB HDMI to VGA : I would not use that but it out there : https://www.amazon.com/Cable-Matters-Active-Adapter-Support/dp/B008O7RH5C DVI-D to VGA : use current VGA cable and plug to on one end and plug it in video card https://www.amazon.com/Male-DVI-D-Female-VGA-Adapter/dp/B007EA48MA Upvote 0 Downvote
S seedzzz Commendable Jan 14, 2017 2 0 1,510 Jan 14, 2017 #3 I've got that DVI-D to VGA adapter but won't work 🙁 Upvote 0 Downvote
Z ZapBoy Commendable Feb 2, 2017 16 0 1,520 Feb 4, 2017 Solution #4 seedzzz : I've got that DVI-D to VGA adapter but won't work 🙁 The DVI-D won't work, get a DVI-I instead, they're not the same! Hope this helps Upvote 0 Downvote Solution
DRagor Polypheme Jan 23, 2017 9,098 813 65,440 Mar 19, 2017 #5 seedzzz : I've got that DVI-D to VGA adapter but won't work 🙁 If the GPU has DVI-D port and does not have DVI-I port, the ONLY thing that will work is active adapter DVI-D to VGA. Upvote 0 Downvote
M mikeyj001 Prominent Apr 29, 2017 1 0 510 Apr 29, 2017 #6 seedzzz : I've got that DVI-D to VGA adapter but won't work 🙁 Did you find a solution to this problem? I have the same card and issue. Have you tried a DVI-I to VGA converter for analog signal to the monitor? I'm going to get one to try. Upvote 0 Downvote
