Ive got the parts, now how do I...
Archmonarch
...put them together? Can anyone recommend a good builder's guide? All the ones Ive found are 2-3 years old. I dont want to make a mistake and possibly damage my expensive components. As youve probably guessed, this is my first build and I have little idea what Im doing.
Thanks.
STEP #1 - Take the motherboard, CPU, and case out of their boxes.
Abit IS7 - 3.0C @ 3.6ghz - Mushkin PC4000 (2 X 512) - Sapphire 9800Pro - TT 420 watt Pure Power
Samsung 120gb ATA-100 - Maxtor 40gb ATA - 100
Sony DRU-510A - Yellowtail Merlot
Remember when you were little and you had those toys that had shapes and you had to match them to fit them through? Yeah, it's kinda like that :wink: .
Maxtor disgraces the six letters that make Matrox.
Remember it is best to assemble parts on a shag carpet, keeps static away.
And large pliers are necesary, along with electric drill driver. And remember to torque up those screws, to reduce vibrations.
Try everything...
Do not be afraid of failure, for this is how we learn and grow...
Live life to the fullest...
Do not regret what you have not yet done!!!
Toms Hardware Guide has a "How To" for computer assembly. You could do a Google search as well.
Da Worfster
Man these guy's are jokers.
If you don't stand for something, you'll fall for anything.
Here's link to THG PC building articles
<A HREF="http://www.tomshardware.com/howto/20020904/index.html" target="_new">Building Your Own PC, Part 1: Know-How for Do-It-Yourselfers</A>
<A HREF="http://www.tomshardware.com/howto/20020918/index.html" target="_new">Building Your Own PC, Part 2: Assembly Step by Step</A>
<A HREF="http://geocities.com/spitfire_x86" target="_new">My Website</A>
<A HREF="http://geocities.com/spitfire_x86/myrig.html" target="_new">My Rig</A> & <A HREF="http://geocities.com/spitfire_x86/benchmark.html" target="_new">3DMark score</A>
My suggestion would be to turn your current computer off and start taking it apart and putting it back together. You can probably afford to make that mistake. Then go ahead and work on the new one.
</font color=red><i><font color=red>GOD</font color=red> <font color=blue>BLESS </font color=blue><font color=red>AMERICA
A trick that I like. You attach the power cord to the case, but leave the power switch off. This grounds the case so it helps prevent static buildup. Not a good idea in a lightning storm though.
You're gonna make this poor guy blow up his stuff Rich, I find it humurous nonetheless.
<i> If the creator of the human body is "The Ultimate Engineer", why did he put a recreation site right next to a waste treatment area? </i>
if you cant find any thermal compound, mix milk with flour. it really works.
2.6C
ABIT IC7-Max3
2x Kingmax SuperRam 512 DDR433
GeXcube 9800pro @ 450/750
80G Seagate S-ATA150
Antec Super Lanboy w/ 350 Smart Blue PSU
Be sure to unplug power supply when connecting power cables on mobo, cards and periphs. Can cause a spike.
Try everything...
