[SOLVED] I've just built a PC and plugged the monitor in and it said No signal
husky2331
32
Today I built a PC for my friend and plugged in every single needed connector and closed the case turned it on and the monitor wasn't getting signal but LEDs and fans vere on.
I've even tried to plug the monitor to Xbox and it worked. And I tried to uninstall the card and plug the HDMI cable into MB's HDMI output and same with DisplayPort.
And another thing I've tried was to remove the CMOS battery and put it back, nothing happened or even doing something with the ram. I'm just out of ideas
Specs:
CPU: AMD Ryzen 7 2700
Motherboard: Asus ROG Strix B450-F gaming
Ram: HyperX 8 GB KIT DDR4 3200 MHz CL18 Fury Series
SSD/HDD: SSD WD Green NAND 120GB / HDD Seagate BarraCuda 1T
GPU: Asus Dual GTX 1060 O6G
PSU: SilentiumPC Vero M2 Bronze 600 W
Chassis: NZXT S340
Thanks.
List your specs like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
You won't get any video output from the board(whatever the chipset is) since you're working with a Ryzen processor, not a Ryzen APU.
husky2331
32
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
Year I know it’s not an APU but I was in a stage that I didn’t know what to do so I plugged evrithing everywhere you know
