Hello,
I’m running Win 7 Ultimate 32-bit OS on my home PC (CPU Intel, Core2 Duo, 3GHz).
I ‘m in front of problems, which I’d like to share with you and hopefully to get some help.
I entered the Control Panel in order to find out the reason for the situation and found the following:
1. Entering: Control Panel\System and Security\Action Center on my PC, I saw a message under Security:
“The Windows Security Center service is turned off”
And
Clicking on the ‘Turn on now’ button I get:
“The Windows Security Center service can’t be started”.
2. Entering Control Panel\System and Security\Windows Firewall, I saw another surprising message:
“Update your FireWall Settings
Windows FireWall is not using the recommended
settings to protect your computer”
When clicking on the “Use recommended settings” button, I get the following error msg:
“Windows FireWall can’t change some of your settings
Error code 0x80070424”.
3. . Entering :Control Panel\System and Security\Windows Firewall\Advanced settings I get the message in the Windows Firewall with Advanced Security window:
“The Windows Firewall with Advanced Security snap-in failed to load. Restart the Windows Firewall service on the computer that you are managing. Error code: 0x6D9”.
4. Entering the List of services (from the Task Manager) I can’t see the Windows Firewall service at all as it is not listed! And can’t be restarted as well.
As the above messages concern the Windows security system of my computer I would like to know if the computer is in a real dangerous state. And what should I do to correct it.
I’m using MS Security Essentials and Malwarebites’ Anti-Malware; both apps report no infections on my computer).
I do hope someone help me. Thanks.
C.J.P
And
C.J.P
