Ive tried everything help!
Apr 3, 2018
Alright guys hold on tight ... Cuz im fuming while im writing this ... So like 2 months ago i bought a really nice windows 10 hp ... Ive taken really good care of it .. None the less.. Today i " improperly " turned it off by pressing the button instead of turning off internaly ... So i get back from work and turn it back on ... And my screen is saying "repairing disks" and I'm like wtf ? Cause like ive said ive taken good care of it and its always been crazy fast and no issues ... Well this " repairing " thing ends and I'm looking at my desktop .. I go to click on one of my programs and it says file cannot be executed SspiCli.dll not found ... In fact it says this error with every single one of my programs and on top of that anything i try to download as well ...
So with some talk from microsoft suppprt we came to the conclusion to restore it because this [CENSORED] just happened today so I tried to restore it does its thing and at the very end when it gets back to desktop it says " an error occurred and no changes were made " ya ya yata and then something about a firewall maybe blocking some files ... So i turned my protection / firewall conpletely off and tried to run it again and the same thing happened .. Ssme error ...
So then I decided screw this and try to do a complete reset ... It gets about 38% through that and stops and says " undoing changes " so now it wont let me into my desktop now ... It keeps Stoping while booting saying errors occured and running automatic repair over and over nothings happening .... On top of this i fully scanned my computer " 0 threats " and my computer is " healthy" ... Seen something in a forrum about running command prompt chkdsk c: /r /x scanned it fully then attemptrd to adv /scannow to repair and it wasnt having it and says something about it being denied ... So idk u guys I'm freaking out .. Halp please
Hello,
I have a little baby that is constantly sneaking up on me and pressing my power button on the PC and shutting it off. This does absolutely no harm whatsoever.
https://www.howtogeek.com/181295/yes-its-okay-to-shut-down-your-computer-with-the-power-button/
You might want to tell us what model of HP that you have. Did you check all of the connections? This might be a RAM issue so I would check the RAM to see if it works correctly.
https://www.howtogeek.com/260813/how-to-test-your-computers-ram-for-problems/
Hello,
