Ok guys i just sold my q6600 build i had running for almost 5 years and i'm looking into building a new build...
It's supposed to last me atleast 3 years running everything max at 1366x768...i don't mind updating de graphics card in a year and a half tho.
The things I am sure I want.
Case: Fractal Design Core 1000
PSU: OCZ Silencer MK III 500w
Optical Drive: Sony Optiarc DVD-RW
Now theres a few things i'm not sure about...I'm pretty sure i should get a z77 motherboard. I'm thinking about the asrock z77 pro4-M. What I don't know is if i should get a i5 3570K or a 3550 since the case doesnt really support big cooler and ivy bridge is a bit on the hot side. I would have to do some modding to get a h60 for example in a push pull config at the front and even then i probably wouldnt be able to push it over 4.2Ghz max so i dunno if it is worth the trouble. Also i was expecting to get a GPU like hd 7770...around that type of performance wich should be plenty of horsepower at that res to max everything...i dont look for crazy high fps i just want 30 minimum and with lucid logix virtu boost i should be getting pretty much everything i need i think.
So what you guys think, would i be fine with a non-OC-able CPU and a entry level card for my needs? or is it worth spending the extra money? like say a 230$ gpu and 50/60$ cooler and 20$ more for a k series? is it worth? what gains should i be expecting for that kind of money?
