JAVA PROBLEMS on laptop
Lonnie hesnley
I have a window 7 hp quad 4 I am trying to install a program called "YAW CAM" which works with a existing web camera and uses motion detection . but when I install the yawcam it says :
you need to install:java runtime environment(jre)6 (or later)to be able to run tawcam.
get it from :http//www.java.cpm
do you want to go their now ?
i have also checked and can find no java file folder in the programs or programx86 folder . in my google and firefox i checked and the java applet is enabled . but when i download the java from the link above and install it it does nothing. and if i try to install the yawcam again it says the same error message . it also says you can install yawcam anyway without the java but it might not work , install yawcam anyway? even though the setup could not find the required software you can install yawcam anyway. yawcam might not work, but you can always install the requirements afterwards.
i have done that and when i try to open it it goes back to the same error message .
YAWCAM LAUNCH ERROR:
COULD NOT FIND JAVA ON THE SYSTEM. PLEASE REINSTALL JAVA.
ERROR CODE 9009
I have been trying to get java working for about 4 days straight , "CAN ANYONE PLEASE HELP ME ??
Hi,
Download the 32 bit as well as the 64 Bit versions of JRE from the manual download page:
https://www.java.com/en/download/manual.jsp
After completion of download, uninstall all java and YAWCAM if any installed.
Restart the system, and install the downloaded application.
First the 32 Bit and then the 64 Bit executables.
Restart once installation is completed.
Start YAWCAM installation. hope this resolves.
