Jerky and jagged mouse movement and registry errors?
ambam
1,166
I've been having some bad problems with jerky and jagged mouse movement for the past Two weeks, and after I downloaded a registry cleaner (CCleaner) and ran it, this problem disappeared.
I was terrified it was a hardware issue, or something wrong with the USB ports.
Can registry errors effect mouse movement? How else can registry errors effect your computer?
Is Piriforms "CCleaner" a popular and trusted program used by many people? How often should I clean and correct my registry?
Yes register errors could cause the problem you experienced. It is due to a busy CPU that is trying to find a program or has wrong settings to run a program.
CCleaner is a great trusted register cleaner which I only use when I still experience problems after have scanned for Maleware and Virus.
In a worst case senario a register error can lead to a computer not booting up anymore.
running CClean after having uninstalled multiple softwares to clean up leftover program entries.
ambam
1,166
Thank you!
