L lyja.vp Sep 23, 2018 1 0 10 Sep 23, 2018 #1 Hello So im just wondering can you join like to a cs 1.6 lan server that has been hosted using wifi connect to it using wired ethernet (same router) beacouse my friend hosted using wifi and server didint come up in lan tab (im using wired ethernet)
Solution kanewolf Sep 23, 2018 A wired and wireless host on the same router should be able to communicate. There is a configuration problem somewhere rather than a network problem.
kanewolf Titan Moderator May 29, 2013 38,237 3,627 156,790 Sep 23, 2018 Solution #2 A wired and wireless host on the same router should be able to communicate. There is a configuration problem somewhere rather than a network problem. Upvote 0 Downvote Solution
