Joust power supply question
mark
2,613
Archived from groups: rec.games.video.arcade.collecting (More info?)
I bought a broke Joust this weekend and the Power supply is out.
Arcadeshop has one for sell that is a 15amp.I have a 12amp PS,is this
enough or due to all the boards does it need to be a 15amp to come on
and work?Thanks
mark
2,613
Wow, I appreciate the info but didnt want to spend any money if my
12amp ps would work.Doesnt make since to go buy all these adapters and
kits if i have something that will work.
12amp yes no?
G
Guest
Guest
mark <rcsystms1@aol.com> wrote:
: I bought a broke Joust this weekend and the Power supply is out.
: Arcadeshop has one for sell that is a 15amp.I have a 12amp PS,is this
: enough or due to all the boards does it need to be a 15amp to come on
: and work?Thanks
Why not just fix the original power supply? :)
Joust doesn't need anywhere near 15A on the +5.
Mark Spaeth mspaeth@mtl.mit.edu
50 Vassar St., #38.265 mspaeth@mit.edu
Cambridge, MA 02139
(617) 452-2354 http://rgvac.978.org/~mspaeth
G
Guest
Guest
you can get rebuild kits from bob roberts... he'll also sell a replacement
switcher WITH the harness to connect it...
or you can throw in the switcher you have. make sure you wire it up
correctly though... there are some non-standard voltages on the original
supply (the 24 volts for the sound for example).
check out www.robotron-2084.co.uk
it's a nice site with a lot of info...
specifically http://www.robotron-2084.co.uk/techwilliams2jamma.html#power
has info on how to hook up a switcher.
steve
"mark" <rcsystms1@aol.com> wrote in message
news:1124732697.573803.67290@z14g2000cwz.googlegroups.com...
>I dont have the stuff to fix the o.g. power supply but i have a 12amp
> switching ps
G
Guest
Guest
yes
news:1124743608.074936.50260@g43g2000cwa.googlegroups.com...
> 12amp yes no?
