So My AMD FX-8350 (Stock settings) used to run at about 40-50 degrees (all measurements are done in Celsius) idle and 50-60 degrees under load, I cleaned out dust using compressed air and it dropped all temps by about 10 degrees, I then took off my cooler, cleaned the thermal paste of (of which there wasn't as much as I had expected) and put on some new paste and the temps have dropped by 10 more degrees (20-30 idle, haven't tested under load yet).
I know that these temps are better (lower is always better, in this case) but does it sound like false readings or does it sound about right?
P.S. These temps where recorded by the same version of Piriform's Speccy.
