Just Cause 3 Stutters and Some Times Lag After Playing Some time.....Pls Help
Mohammed muhsin
189
Hi
I Have A Gtx 960 4GB Asus Gpu
I5 4440
B85M Gamer Motherboard
8GB DDR3 Kingston HyperX Fury Red Ram
When I Play Just Cause for 30 to 40 Minutes I am Getting 60+Fps On Max Setting
After Some Time Fps Starts Dropping When We Turn The Mouse Or Start Moving
Most of the times Fps starts Dropping When Playing Story Missions With Lot of Explosion And Gunfires
It will Freeze and Stutter
It Irritates Me PLS HELP
(Edge Fade Is Off)
Just Cause 3 is known to suffer from memory leaks, and that can lead to poor performance for users with systems that only have 8GB of RAM. Check your RAM usage while playing, if it's maxing out when the game slows down, you're either going to have to restart the game to clear the memory leak, or look at getting more RAM to accommodate the game's excessive memory demands.
Will it Help If I Change The Priority To High
