Well first visualize this picture and notice 4 things, Just Cause 2 low FPS, CPU usage, RAM usage, and GTX 570 usage none are 100% in use so that being said im very puzzled and for this first time ever I have to post on a forum since I honestly dont understand what is happening.
My specs are:
-NVIDIA Geforce GTX 570
-Phenom 9600 x4 2.3ghz
-3gb ddr2 RAM
-600 watt corsair PSU
(I know its all very outdated but I dont understand why that low fps when nothing is full in use)
Also I belive it is my cpu Cache :s Its my assumption because its 2mb well 3mb with the other L2 but you guys can look up the specs.. Lastly I am going to upgrade to 8gb ddr2 ram 800mhz or the fastest I found out there in newegg, and a AMD Phenom ii x4 3.0ghz with 8mb of cache in total.
But I will only if you guys believe that my main issue is because of those.Oh before I forget, Every other game like portal2 and teamfortress run pretty good on high graphics my only problem with those is that I run out of ram and it slows down but its great for the most part.. But in this case window'd and low settings without running out of ram:17 fps...
Thank You And I Kindly will appreciate any help at all
My specs are:
-3gb ddr2 RAM
