99.999% sure i'm not going to do that, i'm just curious to know if it would make sense. Replacing the radiator of cpu water cooling loop with a cpu heatsink attached to a peltier module's cold side; placing it before the cpu heatsink, not after.
I never had one so that's why i'm asking. Is there any risk the liquid will freeze? Is there any way to control the cold side? Would this prevent the need for condensation-countermeasures, since the cpu wouldn't get as cold as it would with the more standard peltier attached directly to it?
If water cooling is enough in winter but not in summer, since peltier consumes more energy, would it make sense to make a "switch" in the tubes so you can make it pass through the peltier section or bypass it? (of course would turn the peltier and its fan off as well.
Or i'm just crazy?
Or i'm just crazy?
