[SOLVED] Just found a Kingston DTVP 3.0 usb. Would lijke to clear it and use it as a simple storage device. Is that possible. and if so, how do I do it? Thanks
Here is a simple step by step guide to formatting your USB drive.
https://www.windowscentral.com/how-format-usb-flash-drive-windows-10
Once you have it formatted, you will be able to use it as storage by coping and or moving what ever file(s) you want onto the drive. You will only be able to access the files when the USB drive is installed into the USB port on your motherboard or case. It should work with USB 2.0 or 3.0 but you'll have faster speeds with USB 3.0.
