Just got a 5770 and an Antec 650 Power supply and NIC card doesnt work
Amstel33
4
Core 2 Quad Q6600 (K) 2.4 GHz (95W)
800 MHz front side bus
Socket 1066
Motherboard Name: IPIBL-LB
Sapphire 5770 Card
Antec Earthwatts 650 Watt Power Supply
4 gig ddr2 Ram
The specs on the motherboard say 1 pci-e x16 slot could that be the problem since it doesnt say pci-e 2.0?
Ok what happens is when i turn on any game the NIC card stops working. It works fine until I turn on any game. I have already downloaded and installed the recent drivers for the video card.
Hm. How do you everything plugged in powerwise outside the case? I had an issue with my monitor going black during gaming at times and turned out I was running too much from one cord(pc is on opposite side of room from outlets, so had to run heavy duty extension cords), but once I split it up between a couple of outlets the problem vanished. Might start there.
That would be the first place I'd start man. In my situation, the monitor just went black, but stayed on, the game stayed on as well, and the tower as well. The other things you could try I guess would be check for updated NIC drivers. If none of this works, you could always grab a cheap add in NIC card that fits in a PCI slot.
