Approximate Purchase Date: ASAP, but can wait until prime day if prices are expected to go down for the sale.
Budget Range: $1000 pre tax, not including GPU or storage because I already have those. I am flexible on the price if it makes sense for the build and what I want. This budget is just for the CPU, motherboard, RAM, cpu air cooler, power supply.
System Usage from Most to Least Important: Mainly 1440p 144fps and 4k 60fps gaming, and regular web surfing
Are you buying a monitor: Not right now, I will purchase a 1440p 144hz in the future. Right now I will be using a 65inch LG C9 OLED.
Parts to Upgrade: CPU, Motherboard, RAM, CPU Air Cooler, Power Supply
Do you need to buy OS: No
Please note that if you're using an OEM license of Windows, you will need a new one when buying a new motherboard.
Preferred Website(s) for Parts: I prefer Micro Center, but wherever I can get the best deal.
Parts Preferences: CPU - AMD or Intel, whichever would be better
Motherboard - Gigabyte/Asus
RAM - G Skill, Corsair
Power Supply - no preference
Air Cooler - No preference
Overclocking: NO
SLI or Crossfire: NO
Your Monitor Resolution: 4k 65inch LG C9 OLED, will purchase a 1440p monitor in future.
Additional Comments: I just purchased a 7900xt, now I need to figure out the rest of the parts. I don't care about having RGB, would prefer not to have it but if the best part for the price has RGB then I'll take it. I will decide on a case last.
And Most Importantly, Why Are You Upgrading: My current PC that I built is over 8 years old, I want to be able to play recent games at 1440p on high settings with high FPS.
My parts that I picked out:
CPU
ryzen 7 7800x3d
https://www.microcenter.com/product...-8-core-boxed-processor-heatsink-not-included
This should be the best for gaming and for the 7900 xt right? I was debating on getting an i5 13600k but decided to spend the extra money and just go big here, is this CPU necessary for 1440p/4k gaming with a 7900 xt?
Motherboard
Gigabyte B650 Aorus elite
https://www.microcenter.com/product/659691/gigabyte-b650-aorus-elite-ax-amd-am5-atx-motherboard
This pretty much has enough usb/sata/nvme ports that I need.
Does this board have good vram and can I control the case fan speeds with this board so the fans aren't always running at full speed and auto adjust based on what the PC is doing?
RAM
g skill trident 32gb ddr5 6000 cl30
https://www.microcenter.com/product...top-memory-kit-f5-6000j3038f16gx2-tz5nr-black
g skill trident 32gb ddr5 6000 cl36
https://www.microcenter.com/product...top-memory-kit-f5-6000j3636f16gx2-tz5nr-black
I am leaning towards the pricier one since it has a better CL for only $15 more.
Air Cooler:
Thermalright Phantom
https://www.amazon.com/Thermalright-Phantom-TL-C12B-Technilogy-Bearing/dp/B0BNDTJVPL
deepcool ak620
https://www.microcenter.com/product/645414/deepcool-ak620-cpu-air-cooler
I know the noctua nh-d15 is king but I think it's overkill for the 7800x3d right?
Is the thermalright the better option here?
I would prefer the quitter cooler if they perform similarly.
Power Supply:
corsair rm850x
https://www.microcenter.com/product...t-80-plus-gold-atx-fully-modular-power-supply
Overclocking: NO
CPU
ryzen 7 7800x3d
Motherboard
RAM
Air Cooler:
deepcool ak620
Power Supply:
corsair rm850x
