Just put together my first pc parts list can anyone tell me if its good??
You need a Z170 chipset to OC that CPU. There is no point to spending extra on that memory. You are capped at 2133mhz with that chipset.
This system will have a much better build quality and perform faster for just a little bit more.
CPU: Intel Core i5-7600K 3.8GHz Quad-Core Processor ($229.00 @ Amazon)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler ($34.99 @ Newegg Marketplace)
Motherboard: MSI Z270M MORTAR Micro ATX LGA1151 Motherboard ($104.99 @ Amazon)
Memory: Patriot Viper Elite 16GB (2 x 8GB) DDR4-2666 Memory ($97.99 @ Amazon)
Storage: Zotac T500 240GB 2.5" Solid State Drive ($69.99 @...
Storage: Zotac T500 240GB 2.5" Solid State Drive ($69.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.89 @ OutletPC)
Video Card: Zotac GeForce GTX 1070 8GB Video Card ($359.99 @ Newegg)
Case: NZXT S340 (Black/Red) ATX Mid Tower Case ($64.99 @ Newegg)
Power Supply: SeaSonic 520W 80+ Bronze Certified Fully-Modular ATX Power Supply ($56.99 @ SuperBiiz)
Operating System: Microsoft Windows 10 Home OEM 64-bit ($89.98 @ Amazon)
Total: $1158.80
Generated by PCPartPicker 2017-04-24 13:38 EDT-0400
Here's a suggested/alternative parts list with updates from your initial list to make it compatible and better:
CPU Cooler: Cooler Master Hyper 212 LED 66.3 CFM Rifle Bearing CPU Cooler ($19.99 @ Amazon)
Memory: Corsair Vengeance LED 16GB (2 x 8GB) DDR4-3000 Memory ($114.99 @ Amazon)
Video Card: MSI GeForce GTX 1070 8GB Video Card ($404.99 @ Amazon)
Case: DIYPC Ranger-R4-R ATX Mid Tower Case ($44.97 @ Newegg)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply ($69.39 @ SuperBiiz)
Total: $1128.19
Generated by PCPartPicker 2017-04-24 13:43 EDT-0400
Note that in your parts list, you got an overclockable i5-6600K but paired it with a non-OC H110M mobo - so that was changed, among others.
CPU = Upgraded to a better/faster Kaby Lake i5-7600K (3.8GHz to 4.2GHz) than the Skylake i5-6600K (3.5GHz to 3.9GHz).
MB = Got a Z270 mobo that supports OCing that CPU, and, it's got Red Ambient LEDs.
RAM = Got the RAM with RED LEDs, with same 16GB as you want, but at a faster 3000MHz speed.
HDD = Same.
GPU = Same.
Case = Got a good budget Black + Red ATX case (Ranger-R4-R http://www.mydiypcusa.com/products/cases/atx-midtower/ranger-r4-r.html). Its already pre-installed with 3x fans (1x 140mm Red LED Fan at side, 1x 120mm Red LED Fan at front, and 1x 120mm Fan at rear).
PSU = Got a better quality PSU (Seasonic G Series) which has more than enough wattage for your rig. The G-550 has hybrid-modular cables and has 5-year warranty.
OS = Changed from Windows 10 Pro to Windows 10 Home (cost-cutting).
All in all, the upgrade/updated parts list approx the same cost as your initial parts. Hope this helps.
hondarace7270
that does Thank you!
