just some clearification if my build will work fine.
eddystoner15
94
hi, im wondering if my build will work together with no troubles and if it will fit in the case. my parts are:
Seagate Barracuda ST31000524AS 1TB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive
GIGABYTE GA-970A-UD3 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard GIGABYTE GA-970A-UD3 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
CORSAIR Builder Series CX600 600W ATX12V v2.3 80 PLUS BRONZE Certified Active PFC Power Supply CORSAIR Builder Series CX600 600W ATX12V v2.3 80 PLUS BRONZE Certified Active PFC Power Supply
G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
AMD FX-6300 Vishera 3.5GHz (4.1GHz Turbo) Socket AM3+ 95W Six-Core Desktop Processor FD6300WMHKBOX AMD FX-6300 Vishera 3.5GHz (4.1GHz Turbo) Socket AM3+ 95W Six-Core Desktop Processor FD6300WMHKBOX
I will be playing games, watching movies, surfing the web and home work from school on this computer. I aleady have a cooler master elite 330 case and a sapphire radeon hd 57501gb vapor x i will be using. if you would like I will post the prices up later. thank you
ok thank you for the quick response. yea I only plan on playing games like minecraft, ace of spades, amnesia, payday the heist, and some older popular games like grand thefte auto. I plan on upgrading to a 7790 or 7870 or gtx 660 in the later future to play bigger games like bf3/ the upcoming bf4 on higher settings. I will be playing on a 24" tv as a monitor via hdmi. and I plan on getting these parts on newegg.ca as I live in Canada. and do you think I should get thermal paste? im positive with the fx chip the heat sink already comes with some applied but should I just get an extra tube?
so ill order these parts then. and I have a old 160gb hdd with windows xp ill use then just upgrade from xp to windows 7 right from that hard drive. so ill have 2 hard drives plugged in, one with windows xp and other programs. I should just boot right up into xp then right? no messing with bios or nothing like that?
There will be an application of paste on the new heat sink. If you plan on replacing it (AMD stock coolers aren't great, especially if you want to OC), a new cooler (I recommend the Xigmatek Gaia; cheaper but comparable to the more-often mentioned Hyper212 EVO), the new cooler will also come with paste.
And, your discovery about moving an existing drive is correct; it almost never works, and when it does, the result is generally never "right." A clean install is the way to go.
