What is your parts list?
Intel i5-4590 | Gigabyte Z97MX Gaming 5 lga 1150 | Corsair CX600M | MSI GTX 970 | 8GB DDR3 1866Mhz RAM | DVD/CD drive | Toshiba 1TB 7200RPM HDD | Western Digital Blue 1TB HDD | ADATA 480GB SSD | 2 Noctua case fans | Cooler Master Hyper 212 Evo
Describe your problem. List any error messages and symptoms. Be descriptive.
I just swapped in a new motherboard and CPU, went from AMD to Intel. Added an SSD as well. Just finished and plugged in the necessary cables into the rear IO ports. I turned on the computer, it turned on, the MSI GTX 970 logo light turns on, the two fans spin, none of the case fans or the CPU cooler fan spin at all, the PSU fan spins, I can hear and feel the HDD spinning (only have the Toshiba drive plugged into a SATA port), the hard drive activity light does not turn on (but I may have plugged in the front panel connector for the light the wrong way), and the monitor stays on standby and doesn't even turn on or change from pure black. No beeps at all from the speaker I plugged into the header, and I tried both ways to make sure I didn't plug it in wrong.
List anything you've done in attempt to diagnose or fix the problem.
Plunged in the monitor to the motherboard HDMI port instead of the GPU HDMI port, did nothing. Made sure the 24 pin connector is in right. Made sure the SATA connect is in well. Made sure the case and cooler fans are plugged in right.
Post relevant photos of build/parts here.
Don't know if these help, but here's a couple of after the swap, and I have more if they would be helpful.
http://m.imgur.com/a0KsAln,3Gc50Vn
Provide any additional details you wish below.
I had uninstalled numerous drivers that had any association with the last motherboard right before starting this motherboard and CPU swap, like the audio, graphics, video, ethernet, sata controller, etc drivers. I did this to avoid having to fresh install Windows after the hardware swap. I learned that this should be done to achieve this goal from a couple popular YouTube videos that instruct you to do this in order to avoid a Windows fresh install when changing your motherboard. Many people said it worked for them and the video creator did the same in his recording and showed that it worked after the hardware swap. I don't think it has anything to do with drivers or hard drives, since it should still POST or show the BIOS screen, and the fans should at least spin for a second.
I have no idea how to proceed and Google has done little to help. Any help is greatly appreciated. Thanks.
