to know more about cpu i was wondering if the cash is more important than its cycles speed
i know what the cash is but can't determine which is more important
Neither of those sites is perfect but as a rough comparison they do the job, and you can see that i3's got better in those 3 generations as you'd expect.
Not nearly enough info.
The actual CPU's matter, not just the GHz or cache amount.
A 2 GHz CPU from 2018 is 'faster' than a 3GHz CPU from 2004.
Everything about it. You can't get caught up on every little single detail listed on the spec sheet especially when the only thing that matters is the performance in the end.
I wouldn't suggest cpuboss or other boss sites as they rate on irrelevant spec comparisons and many benchmarks were shown to be wrong. Your link actually shows an instance on performance. Userbenchmark is ok but keep in mind they are based mainly on synthetics and not real world difference. It's good to get a quick general idea but that's it.
cpuboss does often have errors, but it also has a list of specs and some benchmark results so if you read the whole page and don't use it as your sole source of comparison it can still be useful. I did say neither site was perfect.
