I spilt soda yes yes. I immediately unplug and shut down PC and then proceeded to take apart the k70 and air it and dry it. I put it back together and it works. All but the buttons on the top, to the right of the media, the windows lock, custom mode and light brightness. I relised when taking it apart a second time that a ribbon cable was lose. Fine but then the ribbon cable wont stick. Is there a solution to this or do i have to RMA and face the wrath of corsair for my stupidity?
http://imgur.com/cW6yCOn
http://imgur.com/ooI8T7m
The first shows me holding it down and that allows me to change the brightness and activate the windows lock. I dont want to spend 40$ to RMA because I live in malaysia BUT I have to order keycaps because some broke(before hand) and I am anyways spending around 50 US for that and I might as well get the keyboard fixed and I think corsair gives you keycaps with it so it would around the same price. But I doubt that. I have absolutely no idea but I just need to go back to mech keyboards soon.
EDIT: The sticker on the back is damaged. I know that voids warranty.
