K7S5A Pro and Boot Device Failure
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.elitegroup (More info?)
I just built a Windows 2000 system around a K7S5A Pro (Version 5) using the
e030811s.rom (BIOS). Every so often almost immediately upon boot up I get a
"boot device failure" error. I then hit ctrl-alt-del and it (usually) goes
on to boot normally. I have thoroughly checked out the Western Digital hard
drive (Norton Disk Doctor, etc.) and have found no problems with it. (The
only other "symptom" is that when the system does boot into Windows 2000 it
takes several minutes (2-3) for it to reach the desktop. It sort of "hangs"
for a couple of minutes at the Windows 2000 splash screen and the status bar
stays at the half-way mark for quite some time. Once into windows everything
runs perfectly.)
Is this a motherboard problem or a hard drive problem? If it's the mb is
there a BIOS setting or update or tweak I need to check out? If the hard
drive is "marginal" I suppose I can wait until it fails, but I would like to
track down and isolate the problem.
NOTE: Here are some things that are *not* the problem. It is not a virus or
spyware or adware or too many programs loading at Windows startup. I have
already checked for these issues. The system is clean. The install of
Windows 2000 is new and all patches and updates have been done.
Thanks!
Interestingly I recently had similar problems with a WD 80Gig wd800jb
HD. Search Usenet and you should find my posts and responses. I did
not find a solution, but the HD works perfectly with another mobo.
What I found was if I stalled the HD boot (enter BIOS setup or boot to
a floppy) for a few minutes, then performed a soft-boot, then win2k
booted properly. You might try using master/slave jumper settings
instead of cableselect. I was using cable select at the time.
Best regards,
Kyle
"skippi" <none@none.com> wrote in message
news:_7rnd.68296$SW3.34083@fed1read01...
using the
I get a
(usually) goes
Digital hard
(The
2000 it
"hangs"
status bar
everything
| runs perfectly.)
mb is
hard
like to
virus or
have
of
| Thanks!
I just wanted to say thanks to kyle and smoker. Your answers are very
informative and have helped to "solve" (i.e., provide a work around for)
this problem.
the
a
hard
it
"hangs"
bar
everything
> runs perfectly.)
to
or
>>> Is this a motherboard problem or a hard drive problem? <<<
It can be a combination of both.
K7S5A has a BIOS drive recognition problem. It doesn't happen very often and
after playing with it, it goes away without you knowing what you may have
done to fix it when it could have just been time alone that fixed it like
the lost CMOS problem. There isn't a fix, it just comes and goes, not
limited to hard drives or only WD.
However, WD is the most notorious of brands for not being recognized by any
motherboard. This became particularly apparent when the nForce 2 boards
first came out. Those boards had an obvious BIOS problem, but every forum
you looked on had a bunch of complaints about WD drives not being
recognized.
The fix that always worked was to (perform surgery) cut the first two wires
of your ribbon cable. WD is aware and has a special cable they'll send you
for free if only you can convince them that every fix they recommend doesn't
work, and you'll really have to beg for it. They work hard at keeping it
private that their drives have this problem. It's most common (and maybe
exclusive) to the 8MB cache drives.
When windows starts up quite slowly it's often caused by your network
settings... or lack of them, i.e., no IP numbers.
To determine what is causing your slow boot time, download a free app called
BLA (bootlog analyzer). This will show you things that startup and quit that
you never heard of and the time each item takes. I think if NDIS..something
is one of the long times indicated, it's your network. Only look at the
Delays, you will see "Failed" in places which is because something is only
useful for a second or so, and Failed usually means the same as Ended or
Quit.
There are various numbers that work to put into your DNS/IP that don't
affect anything. I use these which stop my Win98 from taking an extra 30
seconds to start up without affecting anything else . . .
192.168.255.0 for IP Address
255.255.255.0 for Subnet Mask
In your Network settings, click on your NIC to highlight it then click on
Properties, then the IP Address tab and choose to specify an IP Address.
When I do a clean install this is one of the first things I change because
the time delay can drive you batty since you'll be installing so many things
and having to reboot after.
Well, why not share which "workaround" actually worked with the rest
of us?
Best regards,
Kyle
news:k1Knd.69673$SW3.37677@fed1read01...
very
for)
| this problem.
