My A10-7850k is paired with 8 gbs ddr3 2400mhz ram.
I understand that I can only crossfire up to an r7 250. The queston a lot of people are having is that since the r7 250 ram speed isnt even near 2133 (its in the 1k's), wouldn't it bottleneck the igpu that has access to 2133-2400mhz? If so then it may be better to not crossfire at all as the entire system would run at the GPU speed not the 2400mhz.
With that being said. Would the r7 250x that uses faster ddr5 (I think near 2500mhz) crossfire with the igpu at 2400mhz? Would the system run at 2400mhz since it is the lowest speed in this case, basicly forcing the dedicated GPU to run in ddr3 mode? Or would the igpu simply share the dedicated gpu's ram, allocating the 2400mhz ram for CPU purposes only thus limiting bandwidth to 2 gbs?
I really hope someone can answer this. No one has after asking hundreds of times on YouTube, and elsewhere. Thanx toms community!
