I currently have an i5-4670k at 4.5 Ghz being cooled with an H100i but I want to upgrade to a 5930k at 4.5 Ghz. My current build gets kind of hot, hitting 90C on Prime95 so I think I need to check the mounting since it looks kind of loose. Since I'm going to take it off for a new build, I was thinking of replacing the fans with Gentle Typhoons AP-15. My main reason for doing this is noise. When I wake the computer from sleep, the fans spin up to 100% for about 10 seconds and they are really loud. Would it be worth it to swap these out with two GT AP-15s for noise and slightly better cooling or should I save $40 and keep the stock corsair ones?
Link to fans
http://www.amazon.com/Nidec-Gentle-Typhoon-D1225C12B5AP-Silent/dp/B001Q6RUVO/ref=sr_1_1?ie=UTF8&qid=1434519228&sr=8-1&keywords=gentle+typhoon&pebp=1434519271958&perid=14Z0VP3ZXB7TG0CH8S8F)
Link to fans
