Question kernal power 41 task 63 hard problem .
Mar 23, 2023
hello all of you. I have a problem suddenly on my computer. the only thing i do is that i clean my computer inside and do some calbe managment , thats a tip .
So my computer suddenly freeze or restart.
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Kernel-Power 41
task category (63)
i have
X470 AORUS ULTRA GAMING (rev. 1.0
radenon rx580
amd ryzen 5 2600
ram gskill f4 3000 8gb ddr4 X2
and there is another thing that make me crazy , i open my computer i see on the task 16gb ram then pc freeze and i open it again .
THEN is see my ram as 8 gb and then pc never freeze again .
i really need your knowledge guys ,thanks
and sorry i forgot to tell you what i did .
clear install windows
reset bios
update bios
disable anything from usb 2 and 3 from motherbord.
disable audio cable
disable cables from led +- retart anything only power button that i disable it to make it sure after pc opens
punkncat
Glorious
Ambassador
My first suggestion would be to go in and triple check every connection. Wires, power plugs, RAM, etc and make sure it is all seated correctly. Check to make sure pins haven't pushed out of connectors on the power supply side of the connector at mobo.
If that doesn't work, undo all the wire management you did and check everything closely. With the wire unmanaged see if it will boot.
If that doesn't work, take the system out of the case to "breadboard" with minimal components and check to see if it will boot. Add parts back until it will not. So, for instance, 1 stick of RAM and the graphics card, and start adding bits back to build the system back out.
Mar 23, 2023
does this help u guys?
Description
A problem with your hardware caused Windows to stop working correctly.
Problem signature
Problem Event Name: LiveKernelEvent
Code: 141
Parameter 1: ffffb38f795ef010
Parameter 2: fffff8008e7a66a0
Parameter 3: 0
Parameter 4: 2a4
OS version: 10_0_22621
Service Pack: 0_0
Product: 256_1
OS Version: 10.0.22621.2.0.0.256.48
Locale ID: 2057
Description
Problem signature
Code: 141
Parameter 3: 0
Parameter 4: 2a4
Service Pack: 0_0
Product: 256_1
Locale ID: 2057
No, that suggests possible hardware failure. You need to try the things suggested and feed back here.
Mar 23, 2023
Hello all again and thanks you for your answers
I reinstall every cable and my computer looks fine !
12 hours withous blue/black screen.
BUT on events i still have warning wihout my coomputer shut down .
I have tons of event every 1 min.
DistributedCOM Event ID: 10016
CertificateServicesClient-CertEnroll 86
up to 1000 of this
anyone know ?
