Kernal Power Error Help PLZ!
camokid360
31
I keep on getting random restarts.. could happen every day. or once a week. Also note I also had a storm where the lights where flickering (before i could turn off my pc) the computer lagged 1 screen turned off from lack of power from gpu then came back. My cpu was also overclocked to 4.6ghz @1.34v when this happened. ( i5-7600k, Evga 850 B2, Aorus K7 gaming mobo , corsair 16gb 2400mhz 10CL). I also get errors Distributed COM on microsoft zune video, Gservice, Microsoft photos. Also on steam yesterday before it BSOD i was trying to download a game and the download kept going off back into the queue then i would click it every 10 seconds for it to download... idk seems like i might have a lot of validation errors, corrupt files or drivers or something to do with the harddrive, but idk where to start.. might just do a clean sweep of my pc. Ill make a list of errors from event viewer.
EventID 41
Version 5
Level 1
Task 63
Opcode 0
Keywords 0x8000400000000002
- TimeCreated
[ SystemTime] 2017-04-19T22:55:23.929620200Z
EventRecordID 542
Correlation
- Execution
[ ProcessID] 4
[ ThreadID] 8
Channel System
Computer Jake-PC
- Security
- EventData
BugcheckCode 59
BugcheckParameter1 0xc0000005
BugcheckParameter2 0xfffff800422bec12
BugcheckParameter3 0xffffd10028f866e0
BugcheckParameter4 0x0
SleepInProgress 0
PowerButtonTimestamp 0
BootAppStatus 0
Checkpoint 0
ConnectedStandbyInProgress false
SystemSleepTransitionsToOn 0
CsEntryScenarioInstanceId 0
BugcheckInfoFromEFI true
wuaueng.dll (8044) SUS20ClientDataStore: A request to write to the file "C:\WINDOWS\SoftwareDistribution\DataStore\Logs\tmp.edb" at offset 0 (0x0000000000000000) for 16384 (0x00004000) bytes succeeded, but took an abnormally long time (35 seconds) to be serviced by the OS. This problem is likely due to faulty hardware. Please contact your hardware vendor for further assistance diagnosing the problem.
Failed trying to get the state of the cluster node: JAKE-PC.The error code returned: 0x8007085A
Error code: (HRESULT) 0x8007085a (2147944538) - The Workstation service has not been started.
it would indicate that your network is not connected for some reason.
or a dependency for the network redirector has failed.
IE network driver did not load so the transport could not load and the network redirector can not run.
