[SOLVED] Kernal Power Event 41 Task Cat 63 only when running Rust
Sep 9, 2021
Hello,
I'm looking for help, I'm running the following PC and I'm getting some random crashes only when I'm playing Rust. I can play PUBG, Humankind, Civ VI, Crusader Kings III without an issue. But my friends and I decided to give Rust a try recently and I keep crashing while playing. When I first logged into a server, it lasted about 45 mins without an issue, then I crashed, then it keep crashing when I would load in, sometime it would crash in the settings menu, it is always the same event logger, Critical, Kernel-Power, Event 41, Task Category 63.
I've updated my AMD drivers and GPU Driver. I've tried to play with the Ram settings, I've been using "Auto" but then I tried to use "3400", then I tried "3600", I don't know what else to do, I set it back to "Auto" for now since that was running everything else just fine. Any and all help would be appreciated.
Computer Build:
CPU: AMD AMD RYZEN 7 5800X
CPU Cooler: COOLMAST HYPER 212 RGB BLK COOLER
MB: ASUS ROG STRIX B550-F GAM WIFI
PS: EVGA 850W SUPRNVA G+ 80+G FM
GPU: MSI Gaming Radeon RX 6800 16GB GDDR6 PCI Express 4.0 CrossFireX Support Video Card RX 6800 GAMING X TRIO 16G
Ram: G.Skill Trident Z Neo Series 32GB (2 x 16GB) 288-Pin SDRAM PC4-28800 DDR4 3600 CL16-19-19-39 1.35V Dual Channel Desktop Memory Model F4-3600C16D-32GTZNC
