Kernal Power Event 41
xfire21
49
Second time this happened... Started 10 days ago while i was doing nothing but typing a word document, then stopped. But last night as I was running a pcmark vantage test it crashed again and rebooted =(. I already tried disabling the auto reboot on crash thing and didn't work out. I also ran a memtest86+ and found no errors the first time.
Anyways heres the error
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>2</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000002</Keywords>
<TimeCreated SystemTime="2010-11-03T08:56:54.031616700Z" />
<EventRecordID>22130</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>coolguy</Computer>
<Security UserID="S-1-5-18" />
</System>
- <EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">false</Data>
<Data Name="PowerButtonTimestamp">0</Data>
</EventData>
</Event>
This thing is barely a month old. heres the specs
i5 760 @ 2.8ghz
4GB 1600 G.Skill Ripjaws with XMP on
ati 4350 512mb
Corsair 550WVX PSU
MSI p55 ga55 crossfire board
WD Black 640GB
antec 300 case
Win 7 home premium 64bit
Help =(
How are your CPU and GPU temps? Also, if overclosking anything, revert to default levels and see what happens. Sounds like a possible heat/power issue (hardware) and not a Win 7 problem. The error is just Windows indicating that there is an issue.
Nope, no OC. Although I have XMP enabled for the ram, but I've had that on weeks before the problems started to occur. The thing crashed today again twice when I was running pcmark vantage... I doubt its heat because I used LinX and furmarks to stress both cpu and gpu and it didn't crash.
Maybe driver issue?
