Question Kernel BSOD help
Apr 28, 2020
Kernel_data_inpage_error
My computer was finished yesterday and it worked fine. This morning I left it on while I ate breakfast, and came back to “CRITICAL_PROCESS_something”.
I reset it and it auto joined the bios. I reset again and it went past the bios but gave me “Kernel_data_inpage_error”.
Colif
Win 10 Master
reset or restarted?
Try running memtest86 on each of your ram sticks, one stick at a time, up to 4 passes. Only error count you want is 0, any higher could be cause of the BSOD. Remove/replace ram sticks with errors. Memtest is created as a bootable USB so that you don’t need windows to run it
critical process died would be my guess.
