Question Kernel Error Power 41
Nov 2, 2019
6
Can kernel error power 41 be the cause of a RAMs not compatible with a motherboard or is the the PSU? I tried searching for forums and I see it's mostly the PSU's fault but there was one of my friend says it can also be the RAM's fault. As for the problem, it only occurs with one of the game I play (PSO2) and none of the other games I own in fact, this game have the lowest GPU usage out of anything I own.
SPECS:
Motherboard: ASRock B450M PRO4 AM4 AMD Promontory B450 SATA 6Gb/s USB 3.1 HDMI Micro ATX AMD Motherboard
Ram: G.SKILL Aegis 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3000 (PC4 24000) Intel Z170 Platform Memory (Desktop Memory) Model F4-3000C16D-16GISB
CPU: AMD RYZEN 5 1600 6-Core 32 GHz (36 GHz Turbo) Socket AM4 65W YD1600BBAEBOX Desktop Processor
GPU: MSI Radeon RX 580 DirectX 12 RX 580 ARMOR 8G OC 8GB 256-Bit GDDR5 PCI Express x16 HDCP Ready CrossFireX Support Video Card
PSU: EVGA 600 BQ, 80+ Bronze 600W, Semi Modular, FDB Fan, 3 Year Warranty, Power Supply 110-BQ-0600-K1
SSD: Crucial BX500 120GB 3D NAND SATA 2.5-Inch Internal SSD - CT120BX500SSD1Z
HDD: WD Blue 1TB PC Hard Drive - 7200 RPM Class, SATA 6 Gb/s, 64 MB Cache, 3.5" - WD10EZEX
Fan: Stock fan
Case:Thermaltake Versa H21 SPCC ATX Mid Tower Computer Chassis CA-1B2-00M1NN-00
