Question Kernel Power 41 (63) after changing SATA 2.5" SSD to M.2
Sep 15, 2023
5
So for some context, I built my PC like 3-4 years ago so every component is about 3-4 years old. Recently my ssd started slowing down and corrupted some files but I never got Kernel Power or any other error. I'm 99.9% sure while installing the M.2 I didnt touch my PSU. What may cause this? My specs are:
Win 10 Home
B450M S2H Motherboard
16 GB DDR4 Ram
RX 580 4GB GPU
Ryzen 5 3500X CPU
My old ssd was 240 gb kingston or smth and the new one is Samsung 970 Evo
I also tried updating my drivers, bios and windows but none of them seem to work. I also ran some tests, when i tried to run a stress test for my PSU it gave me the same error on event viewer. Should I try swapping my M.2 slot or anyone have better advice? Lastly, I get the error when I try to play any game even CS:GO crashes after being ingame for 2-3 minutes.
Kernel Power error just means, system has rebooted without shutting down properly first.
If you press reset button - you'll get Kernel power error in alert log.
If get BSOD, this will also generate Kernel power error.
Check cpu and gpu temperatures.
Use MSI afterburner.
What model PSU are you using?
Can you show a photo of info label printed on PSU?
(upload to imgur.com and post link)
My temps were normal (CPU is 55-60, GPU is 50 right now without any loads).
Will check my PSU tomorrow morning, its late now.
I saw someone saying switching the M.2 slot fixed it, should I also try that while checking my PSU model tomorrow?
Checked my PSU model, it's "Platoon Pl-9264". 12 cm 600w
This one?
That is 325W PSU (27A on 12V rail). Nowhere close to 600W.
Recommended minimum for RX 580 is 500W PSU.
Upgrade your PSU.
Yep just checked it again, thats the one.
I don't think I can afford a gold, maybe cheap silver ones or bronzes but would like to hear what you are gonna say, could you recommend some please
Sorry this one is a little too much for me right now, I dont live in a first world country so the budget might change by the taxes taken from that item. (This PSU isnt even available in here, I can order it from Amazon UK but it increases the price drastically) I can do like %50 maybe %60 of this one's price.
