Kernel Power error
Elektro8
Commendable
Oct 20, 2016
43
Hi i seem to be getting this error:
The system firmware has changed the processor's memory type range registers (MTRRs) across a sleep state transition (S5). This can result in reduced resume performance.
Error code: 0x8000000000000404
Do you know how to maybe resolve this?
Spec:
120gb Sandisk SSD
Windows 10
Fx 8370
Rx 460
Ga-970 Gaming
Elektro8
Commendable
Oct 20, 2016
43
I will try :)
Anyway one thing that is different with my problem is that my pc is working normally , it does not shut down when that happens.
While other people said that it does not want to come back from sleep or something.
Anyway i'll see if disabling sleep states helps.
Elektro8
Commendable
Oct 20, 2016
43
I tried, but i cannot find that.
Can you tell me where is that located, or how exactly is it named?
Rusty1983
122
Sorry, My bad.. I believe on that board they are called C3 and C6. Should be in Advanced Bios settings.
Rusty1983
122
It's worth a try.. It won't do any harm and Windows 10 has had problems with sleep states since the beginning.
If it doesn't help, switch it back on.
Elektro8
Commendable
Oct 20, 2016
43
I did.Still in bios cause i see this.
C1E support.
Description is:
Enable this feature will let your system utilize the AMD specific ACPI states to save power consumption.
And yes it is misspeled in bios lol.
It's enabled.
Should i leave it on or also disable that one?
Rusty1983
122
If disabling C6 doesn't work then yes, try it.
Elektro8
Commendable
Oct 20, 2016
43
All i can do is wait and see if that event error appears again.
Now fan is working like crazy.
I have stock one, wraith cooler.
Doesn't bother me, as long as everything works.
Rusty1983
122
Good luck, let me know how things go.
