Hello everyone. So: I used same windows for like 1 year, without any problems. But I decided its time to reset it. The problem is:
After I installed new Windows, my PC keep crashing, without any error, just randomly crashing.(Kernel-Power ID41) Ive read another posts, and its related to PSU and I did all the things they said:
RIG: CPU :FX 8350 with Cooler Master 212 EVO
GPU :RX 480 8GB (Sapphire edition, if helps)
RAM : 16GB of RAM
PSU: 550W Thermallake Litepower
MOBO: GA 970A DS3P (rev 2.0, if helps)
Other things I did:
I disabled fast startup
I cleaned all my pc from dust
I dont think its a PSU problem, I used it for 1 year or more and no problems. I think it[/ICODE]s a software problem. Tell me what to do! Thanks!
- i checked for audio drivers (all good)
- i used MemTest64 for almost 1hours (0 problems, temperatures are good)
- i used Prime95 and OCCT for 1 hour straight (0 problems detected, temperatures are good)
- i did a test using Valley benchmark (0 erros, temperatures are good )
RAM : 16GB of RAM
Other things I did:
