Kernel power issue shutting down randomly and rebooting
puffyluffy
4
Hi I have this issue that my computer randomly shuts down and reboots by itself whenever I play an intense-graphic game. Funny thing is after happening three times, it lets me play the game without any further shut downs. Can anyone help?
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Date: 9/5/2017 11:06:55 PM
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (70368744177664),(2)
User: SYSTEM
Computer: DESKTOP-CAC7QVT
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" ></Provider>
<EventID>41</EventID>
<Version>4</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000400000000002</Keywords>
<TimeCreated SystemTime="2017-05-09T15:06:55.957810000Z" ></TimeCreated>
<EventRecordID>15327</EventRecordID>
<Correlation ></Correlation>
<Execution ProcessID="4" ThreadID="8" ></Execution>
<Channel>System</Channel>
<Computer>DESKTOP-CAC7QVT</Computer>
<Security UserID="S-1-5-18" ></Security>
</System>
<EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">0</Data>
<Data Name="PowerButtonTimestamp">0</Data>
<Data Name="BootAppStatus">0</Data>
<Data Name="Checkpoint">0</Data>
<Data Name="ConnectedStandbyInProgress">false</Data>
<Data Name="SystemSleepTransitionsToOn">0</Data>
<Data Name="CsEntryScenarioInstanceId">0</Data>
</EventData>
</Event>
Sorry i am a little bit under knowledged on the tech side of things. Can you please teach me how do I gry the list of components I have ?
Did you build it or was it bought from a store? Open the case and check which motherboard, PSU and GPU you have. You can also use software like CPU-Z to find the motherboard, CPU and GPU (it won't indicate the specific model number), but you need to visually check what PSU is installed.
My friend asked the shop to build it for me from scratch. I found the receipt and it reads as follows:
Processor : Core i5 6600K
Motherboar : Asus 2170 Pro Gaming
Memory : Corsair 8GB x 2
Hard Drive: Vengeance LPX, Transcend 256GB M 2 Sata
Graphic Card : MSI GTX 980 Ti
Western Digital 2Tb
Power supply : Seasonic x-650
Windows : Win10 home retail
Modem : TP Link T9E
Cooler : Corsair H110I GTX
There you go, I hope this helps. Let me know if you need more information. I thank you for helping out in the first place.
Im having this problem about 7 months,done everything in the internet that says will fix the problem but no luck.It gets worst at night,i cant even watch a movie,the pc shouts down it self and reboot,in day time it happen like 3 or 4 times while gaming,sometimes it wont even load the game,at night i cant do anything,it turns on and thats it,no games no movies nothing,um sick of this now,here are some things i have tried.
Clean install windows 8.1
Updated all the drivers
Rollback all the drivers
Disabled amd audio driver
Disabled fast boot
Re assembled pc
Re applied thermal paste
Checked all the cables
*i dont have any extra hardware parts to rule them out.
*im currently having some issues with ground connection.(pc case leacking electricity)
My pc specs
Intel(R) Core (TM) i5-4590 @ 3.30GHz
MSI B85-G43 Gaming mobo
Hyperx 8Gb ram
R9 380 4G gpu
Corsair VS550 ATX psu
WD 1tb HDD
Toshiba ocz 250 SSD
*Not overcloked
Temps- cpu idle 43 °c,on load while gaming it goes around 70°C,the target temperature in bios is 70°c
Power- 3v-3.408v,5v-5.120v,12v-12.056v/11.965v
Is this somekind a electrical issues in the house? Or poor electricity? i mean mostly this happen at night,as i said before i cant even run a game at night,i an play hours without getting kp-41 in daytime,but sometimes yeah,when gpu on full load,its really hard to notice that its the gpu or the cpu in the msi afterburner,because its really quick,no error msg,just puff restart.
Update- i have tried to re simulate this event,turned off power from the outlet and quickly turned on,same as before pc shouts down and restarted,then checked the windows event viewer,and there i got the same error kernel power 41,*i have noticed the time before do that
A UPS will take over when the line voltage is out of specs. Your description makes it pretty obvious that your utility voltage lacks stability at night; the UPS will kick in whenever it needs to. Don't buy the cheapest UPS that you can find; make sure that it transfers quickly enough to prevent reboot issues with your PC (8 ms is typical, but less is better).
Is your issue resolved by buying a UPS? I'm having the same problem and I'm a little low on funds. So if you could tell me, that'd be great.
