J jeoleo7 Reputable Mar 15, 2014 1 0 4,510 Mar 15, 2014 #1 I formatted my Hp with Home premium which was factory installed with same home premium and that don't have keys. so I thought of using the old keys on my same machine but I cannot read the stickier.Its erased! Is there a way for this???
Solution Someone Somewhere Mar 15, 2014 If you have the original OEM discs from HP, then it can activate using the keys in the BIOS. If not, you'll need to call MS to sort it out.
Someone Somewhere Titan Sep 23, 2012 22,291 8 84,965 Mar 15, 2014 Solution #3 If you have the original OEM discs from HP, then it can activate using the keys in the BIOS. If not, you'll need to call MS to sort it out. Upvote 0 Downvote Solution
