J jakub_12 Commendable Dec 25, 2016 5 0 1,510 Dec 30, 2016 #1 The keyboard sometimes inputs 1 key press as 2, 3 or sometimes even 4. Its not anything with the settings as I checked already. What can I do?
J jakub_12 Commendable Dec 25, 2016 5 0 1,510 Dec 30, 2016 #3 CountMike : Sticky button ? No Im sure that its not a sticky button. Lets say I press P once It sometimes will come up with PPP Upvote 0 Downvote
CountMike Titan Oct 31, 2015 35,722 3,866 147,990 Dec 30, 2016 #4 So, you did set slower repeat rate ? Sometimes even BIOS may have a setting for it. Switch "bounce" is also not unheard of. Upvote 0 Downvote
S SgtScream Splendid Dec 8, 2016 8,535 450 26,740 Dec 30, 2016 #5 Is it with one button or all of the buttons? Upvote 0 Downvote
J jakub_12 Commendable Dec 25, 2016 5 0 1,510 Dec 30, 2016 #6 SgtScream : Is it with one button or all of the buttons? The most common buttons are j u 1 2 3 4 5 6 7 8 9 . Upvote 0 Downvote
S SgtScream Splendid Dec 8, 2016 8,535 450 26,740 Dec 30, 2016 #7 jakub_12 : SgtScream : Is it with one button or all of the buttons? The most common buttons are j u 1 2 3 4 5 6 7 8 9 . Do you have another keyboard to test with? See if you have the same problem with another keyboard. Upvote 0 Downvote
J jakub_12 Commendable Dec 25, 2016 5 0 1,510 Dec 30, 2016 #8 Yeah I'll get a different keyboard and then I will let you know Upvote 0 Downvote
