Keyboard help for a build
looy99
13
am creating my first build, and am still during the planning stage. currently i am selecting a keyboard. i havent been able to find one all that worth while on newegg.com does anyone have any suggestions for a good gaming keyboard (preferably wireless and preferably backlit red)
Corsiar K70, Logitech G710+, Razor Blackwidow (many variations), and CM Storm Quickfire are all very popular and commonly recommended.
If i had to recommend one out of these, it would be the G710+. High quality, more features, and very good customer service.
There is also the less recommended (not as many ppl have it) but tank of a keyboard the is DAS Keyboards. If you punish your keys, this is probably the best one to get. It's build ridiculously tough.
i mean im not looking to buy a $200 dollar keyboard. id prefer something around the $150 or less (preferably less) range
this was actually very helpful. i reviewed them all, and am currently performing a side by side comparison on newegg of the g710+ and the k70
That's a tough choice. I was shopping for a new keyboard just this Christmas and had come down to the same two boards.
I ended up choosing the G710+ over the K70 because I like the fact that the browns come with dampeners. I needed something that wasn't too loud and it fit the bill. You may end up choosing either depending on your needs.
i actually just added the k70 to my list. also, right before you posted this comment, i had happened to post my list and ask anyone for possible advice and opinions, if youd like to see, or voice your opinion, that can be found right here
