Keyboard/mouse doesn't get enough power when re-connecting
Prit369
12
I use my mouse and keyboard for 2 devices (I've tried KVM and same issue), and I notice that sometimes when I switch usb's back, my mouse and keyboard does not get enough power to be usable again.
It DOES power up (I use rat mmo and logitech g15 r1) as my mouse does light up but very dimly. I have to restart the PC to fix the issue.
I have no other USB devices connected, it is using USB 2.0 (not 3), and I have plenty of power from PSU (good PSU 750w delta GPS-750AB, PC only draws at most 200-300w).
Tried using both the front USB ports as well as the rear motherboard USBs during this 'shortage' and it just doesn't provide any power. I tried using a small device like a regular dell mouse but even that wouldn't power on (it's LED just switches on for a brief time when I connect the USB).
Anyone know what the issue could be? Bad motherboard? (I got Asus B85m-e, only a couple of months old) bad PSU? (Never had an issue with PSU past few years). Am I missing some kind of setting in the bios for usb powering?
1| Can you please pass on your full system's specs inclusive of your OS and connected peripherals?
2| Have you made sure your BIOS alongside your necessary device drivers(namely chipset and USB) up to date?
3| It's quite possible you're being under powered although the PSU checks out as capable of delivery it's rated power. You could rule out a faulty PSU by borrowing a reliable, branded PSU of similar wattage from a friend and try it on your culprit system.
