*KEYBOARD PROBLEM* My c key does not work when holding other keys
Feb 24, 2018
When typing or playing a game, my c button does not work, for example when walking forward in rainbow six siege I will try to crouch and it will not work. When holding down a key it will not register me pressing c. This problem only applies my to my c key. Also when not pressing any other key my c key does work.
I can't say for sure in your case, but on most keyboards i have such problems, the mechanics are worn out.
Even though your keyboard is "new"-ish, i'd still assume a mechanical problem. But even if not, it is a problem of your keyboard, and the chances of fixing that are close to zero... 🙁
I don't know if visiting the shop you bought that at is really worth the while - with an expensive gaming-keyboard with golden space-bar and bling-bling it would be a bit different - , but if this annoys you, the best advice i can give is: Buy a new one.
(if you consider this, becoming adventurous and checking it by opening it is ok... :-D)
This depends a lot on your budget, if you are a pupil with your spare money coming from selling matches, i...
This depends a lot on your budget, if you are a pupil with your spare money coming from selling matches, i would reconsider...
