Hi, just bought a new gaming PC and after mounting the components and having the computer ready to install the OS i turned it on. To my surprise my keyboard didn't work for the BIOS interface of the new motherboard.
Now here is the thing: my keyboard is USB (CM Storm Quickfire), and I know some motherboards only work in the beginning with PS2 type keyboard until you enable the USB option later onwards. I don't have a PS2 keyboard around and all my friends only have laptops or USB keyboards as well. The cheapest PS2 keyboard I can buy in my area is 12 bucks, which I don't feel like spending for pressing two 'F-keys' and 'Enter' unless it's completely necessary.
I got angered by the situation so I decided to keep trying with the USB keyboard in different slots, mainly the ones at the back. To my surprise, the fifth time I tried it actually worked, it lit on and everything. It responded enough time to go to the boot options, but as soon as I needed to press the one last button for the DVD drive, it lost connection again. The lights on the keyboard remained on although the keys didn't work anymore. I kept trying to get it to respond and also rebooting and trying to do the process faster. Every 4-5th time my keyboard works, and always until I get to the point where I need to press the one last Enter button, no matter how fast I do it.
I had the DVD with my Windows setup in the drive. I've also tried to see if the DVD can boot automatically, but it seems that I have to select in the BIOS first that I want to boot from the drive.
I've also tried taking the battery out and back in or even changing the USB internal connections and SATA ports of the CD drive of place on the motherboard. What can I do now?
My keyboard as mentioned before is a COOLER MASTER QUICK FIRE USB GAMING KEYBOARD.
My new motherboard is an ASROCK 980 DE3/U3S3 AM3+
The rest of my components in case you need them are:
AMD FX6300 / TACENS RADIX VI 750W / GTX 660 2GB/ KINGSTON HYPER X FURY 1866 2X4GB / SEAGATE BARRACUDA 500GB 7200RPM / LG DVD RW 24x.
Will I need to buy a 12-pound-keyboard with PS2 only to press the two 'F-keys' and 'Enter' or is there any other thing I could try besides that? Thanks a lot in advance for your help.
