Keyboard's Spacebar squeaky noise when pressed
Liron_
101
I got the logitech k120 a few weeks ago and recently i've noticed a very annoying squeaky sound when pressing space. I tried lifiting the space button up with a screwdriver and trying to clean a bit down there but that feels like it solves it temporarily, for a bit of presses there is no squeaky sound but then it comes back.
why should i use to elimiante that sound?
interesting suggestion but i'd rather not. i've not saved the recipment and the box and this problem is so minor its not even noticeable at first (because the actual key presses a bit hide the noise)
though, what i just did to fix the problem is spray under the space bar WD-40 (anti squeaking spray) and it solved the problem for me.
